94 f150 studder
Old Apr 6, 2011 | 06:31 PM
adlkutzler's Avatar
94 f150 studder
I've got a 94 f150 xlt 5.8 e4od and whenever i start it and go to take off the engine sounds like it's flooding out. it kinda stumbles spits and sputters then takes off and drives fine. it only does this when the engine is cold. when it reaches operating temp the check engine light comes on for about 10 mins then goes back off code 173 (rich system). anyone with any input would be greatly appreciated as i have no idea where to start looking for the problem.the truck has 160,000 on the motor about 2,000 miles on the tranny and running gear. my gas mileage has also gone from 12mpg to about 7mpg
Old Apr 6, 2011 | 07:22 PM
One or more stuck fuel injectors.
Old Apr 6, 2011 | 09:51 PM
adlkutzler's Avatar
is there any way to tell witch one it is?
Old Apr 7, 2011 | 02:05 AM
You could pull the plugs and see if any of them are wet with gas or have a crapload of soot on them.
Old Apr 7, 2011 | 12:33 PM
Steve83's Avatar
Before that, pull the red vacuum line off the FPR & check for the presence or ODOR of gasoline. Read this caption:
Old Apr 7, 2011 | 01:32 PM
If it's the FPR, all the plugs will be wet or sooty.
Old Apr 7, 2011 | 02:22 PM
Midwest Farmer's Avatar
What code reader did you use? I cant get any to connect to my trucks computer. Ive got a 95
Old Apr 7, 2011 | 03:56 PM
Unless you have one of the few, 95's don't have OBD2. With EEC, you need a specific Ford code reader.
http://www.amazon.com/Equus-3145-For.../dp/B000EW0KHW
Old Apr 7, 2011 | 08:56 PM
adlkutzler's Avatar
the code reader i used was a OTC mind reader 3750. it works great for what i use it for. the plug for it should be on the driver's side just below the hood hinge kinda a triangular plug.
Old Apr 7, 2011 | 08:59 PM
adlkutzler's Avatar
thanks for all the help i will try a FPR before i go changing all the injectors
Old Apr 8, 2011 | 10:36 AM
Steve83's Avatar
You don't need ANY code reader for EEC-IV; just a paperclip.
Old Apr 9, 2011 | 08:38 PM
adlkutzler's Avatar
thank you for all the help swapped in a new FPR and the thing has never ran this smooth. once again thankyou for all the help
