Lean Mix
Old Dec 16, 2010 | 01:12 PM
jim42242's Avatar
The codes are P0171 and P0174 System too lean bank 1 and system too lean bank 2. I connected a fuel pressure gauge to the manifold and am reading 30psi at Idle. From what I've read it should be between 28 and 45psi, could this be a bad regulator? The engine runs fine, no rough idle or hesitation at all.
Old Dec 16, 2010 | 01:36 PM
jim42242's Avatar
Lean fuel codes
Im getting codes P0171 and P0174 System too lean bank 1 and bank 2. I connected a fuel pressure gauge to the manifold and am getting 30 psi at idle, from what I've read it should be 28-45 psi. The engine runs fne, no rough idle or hesitaton at all, could my regulator be going bad, it hold pressure when engine is shuts off.
Old Dec 16, 2010 | 06:20 PM
Why are you tacking this onto a thread in the pre-1997 forum when you have a 2000?
You probably have a rotten or cracked PCV elbow behind the intake manifold.
