clutch replacement
Old Jun 15, 2010 | 10:24 PM
81mustang's Avatar
clutch replacement
I have a 1992 f150 5.0 with the mazda 5spd. I have to change the clutch and pressure plate and was wondering if i need to to change flywheel or can you just have it turned. Also do you need to change the slave cylinder.
Old Jun 16, 2010 | 01:41 AM
jgger's Avatar
It depends on how bad the flywheel is. If it is scored deep or cracked then yes. Also look real good at the teeth on the ring, that might be the determining factor.
If the slave is internal you have to ask your self "do I feel lucky punk" (Clint Eastwood) or do you want to drop everything again in---oh say a week,a month,2months?
I'd change the slave if it's internal just cuz!
That is my $0.02
Old Jun 16, 2010 | 01:42 PM
the 89's Avatar
Turn the flywheel. Its the best $50 you'll spend. As for the slave cylinder replacment, get one from the dealer because mine I got from Advance Auto Parts started leaking in a about a year with a 1year warrarnty. Their Junk . Had good luck out of their clutch though.
Old Jun 16, 2010 | 02:44 PM
If you are going to the trouble to change the clutch - do everything. Disk, pressure plate, slave/throwout bearing, PROPERLY turn or replace flywheel, pilot bearing, and rear main seal (if it can be changed with just the flywheel removed). Inspect the master cylinder carefully, and if it shows any signs of leakage, change that too.
Old Jun 16, 2010 | 09:38 PM
81mustang's Avatar
thanks. i will check the ford dealer on the slave cylinder. i have to make my mind up if i want to upgrade the clutch and pressure plate to a hays, zoom, or the factory replacement.
Old Jun 17, 2010 | 10:31 AM
If you want OEM parts, you can get a decent discount at tascaparts.com.
