1980-86 door sticker decoder?
Old May 12, 2010 | 07:07 PM
yzmoore's Avatar
I'm trying to locate one and haven't had any luck. Does anyone know which transmission goes with trans code B? on an 83. Also, trans code F? on an 82? I also haven't had much luck with the VIN or the rest of the codes. The vin is 1FTEF14F0DPA26524. Door codes are body-DB4 trans-B axle-19
other numbers on the sticker are F0205
T0481
If anyone wouldn't mind decoding it for me i would really appreciate it. Thanks, Josh
Old May 13, 2010 | 02:04 PM
https://www.f150online.com/forums/ar...tion-page.html
Model: SROD
Type: Four speed overdrive w/ push down reverse
Years: 80-83(4?)
Engines: 300, 302
Fluid: ?
Display:
P..R..1..3
U
S.....2..OD
H
Ratios:
1st 3.25:1
2nd 1.92:1
3rd 1.00:1
4th 0.78:1
Reverse 3.25:1
Construction features: Aluminum, shifter near back
Trans code: B
Model: T18
Type: Four speed, non overdrive, non syncro first gear
Years: ?
Engines: 300, 302, 351, 460, 6.9L
Fluid: ?
Display:
1.2
3.4.R
Construction features: Cast iron throughout
Ratios:
Gas
1st 6.32
2nd 3.03:1
3rd 1.79:1
4th 1.00:1
Diesel
1st 4.02:1
2nd 2.41:1
3rd 1.41:1
4th 1.00:1
Trans code: F or P
Model: T19
Type: Four speed, non overdrive, syncro first gear
Years: up till 93
Engines: 300, 302, 351, 460, 6.9L, 7.3L
Fluid: 140w
Display:
1.2
3.4.R
Ratios:
Gas
1st 6.32
2nd 3.03:1
3rd 1.79:1
4th 1.00:1
Diesel
1st 4.02:1
2nd 2.41:1
3rd 1.41:1
4th 1.00:1
Trans code F or P
Old May 14, 2010 | 12:02 AM
Optika1 illushu's Avatar
T0481
1FTEF14F0DPA26524
1FT - ford motor company USA
E - 6,001-7,000 lb F150/F250
F14 - F150 4wd
F - 302 v8
0 - internal use
D - 1983
P - twin cities mn assembly plant
the rest is numerical serial sequence of assembly.
body-DB4
trans-B could be SROD or TOD, most likely SROD
axle-19 - 3:55 open rear
F0205
T0481
i dont have my complete list handy so i cant get the rest
