Starting issue on a 96
Old Apr 27, 2010 | 02:33 PM
96F150_5.0's Avatar
Hey guys, I'm new as a user, but been surfing the site (and others) quite a bit since buying my truck a year ago. Came time to join some because my truck decided she don't want to run.
It's a 96 F150 Extended cab shortbed, 5.0 automatic. Ran great, got 22 mpg on the road, never gave me issues untill now and I am at a wall as to what the issue is.
A few weeks back, the truck began quitting while driving, just for a split second though. not often, but was annoying. One day i had it running outside and it just quit, wouldn't restart. After about 20 minutes, it fired and was okay but still had the quitting issue. Replaced the module, same problem. Codes said distributor malfunction, so I installed a new one, same problem, but getting worse. would quit while driving, let it sit, disconnect the battery, fired after awhile. Noticed leaking water pump, replaced it AND the crank sensor. Fired up... 2 miles quit, Took it to shop, no codes. Mechanic said computer problem, installed a new one... guess what, no start..
Swapped coil, and coil wire from a running car, no change.
Fuel pump is running
So in short, my truck will not start, just cranks. NEW (not used) parts as follows:
Fuel pump and filter
Distributor
Module
Crank position sensor
computer
Where do I go from here???? Anyone have any ideas?
Old Apr 27, 2010 | 03:03 PM
StrangeRanger's Avatar
You are either not getting spark or not getting fuel.
Which is it?
Old Apr 27, 2010 | 03:23 PM
96F150_5.0's Avatar
Spark. There is no cranking RPM signal
Old Apr 27, 2010 | 05:34 PM
The RPM signal comes from the PIP sensor which is in the distributor.
Since you've replaced the dizzy, I would trace the harness from the dizzy to the PCM. I'd bet on a broken or shorted wire
Old Apr 27, 2010 | 06:16 PM
96F150_5.0's Avatar
Okay, I will get a wiring diagram and check that. Thanks!!!!!!! I hate electrical gremlins
Old Apr 27, 2010 | 07:35 PM
60DRB's Avatar
the wife's '96 Explorer had a 5.0 and we had a somewhat similar issue. Quit on the road once, then started running more and more rough, even backfiring sometimes. Dealer replaced ONE plug and said it was fouled.....uhhhhhh, oooo-K then...? (WTF???) Anyway, I replaced ALL the plugs, no fix, then replaced the spark plug wire set. Presto! Ran perfect. I also hate electric stuff.
Old Apr 28, 2010 | 01:44 AM
masseyman's Avatar
If I was going to take a wild guess, I'd say your replacement distributor(rebuilt I'm sure, as I doubt if you could find a NEW distributor) has a bad PIP just like the distributor you had in there. This happened several years ago on this forum. Rebuilt distributors have a terrible reputation.
Old Apr 28, 2010 | 03:24 PM
ymeski's Avatar
x2.
Old Apr 29, 2010 | 12:02 PM
ymeski's Avatar
But remember, the PIP signal travels through the TFI module to the ECU! Remove the TFI & have bench checked. They also share the same power & ground!
Old May 3, 2010 | 12:12 PM
96F150_5.0's Avatar
Well, still nothing... truck is going to a shop that has alot of electrical experience and has dealt with Ford trucks in the past. I will update progress.
Old May 3, 2010 | 04:01 PM
ymeski's Avatar
Good luck w/ that!
Old May 7, 2010 | 12:18 AM
Filmy's Avatar
This EXACT thing just happened to me. R\New/rebuilt dizzy didn't send out a PIP signal. A new PIP was installed and voila! - no problem. Sucks that this happens, but true.
