keyless entry install
Old Apr 1, 2010 | 10:58 PM
elecunlmted's Avatar
Ok let me start out by saying I haven't seen this discussed well before and second I'd consider myself pretty familar with this subject in general but not specific to this vehicle. What I am having trouble with is this. Everything I've read says the power lock and unlock is in the passenger kickpanel lock is supposively pink/yellow and unlock is supposively pink/green. I take off the kick panel and nothing, I can only find one pink and yellow wire and it leads right to the inertia switch so that's out, there is a strange box factory looking for a red LED facing the rear of the car, anyone have an idea what this is? I just need to know where the lock and unlock wires are or the easiest way to find them and any information related to installing an aftermarket keyless. On the plus side the remote start is working great.
Old Apr 3, 2010 | 04:51 PM
S-crew03's Avatar
What year/model do you have.... the more you provide, the more we can help.
Old Apr 6, 2010 | 09:19 AM
I got it all installed actually, the remote start as easy the tach wire wasn't hard to access except for being in the middle of the engine bay . FYI the lock/unlock wires normally found when you look up the 92-93 f150's are reversed. I pulled mine behind the lock/unlock switch in the driver's side door and ran a wire through the door jamb as I couldn't find the wires behind either kick panel. I can take pictures if anyone needs them.
