Spit and Sputter
Old Mar 14, 2010 | 10:52 AM
Beastly_95's Avatar
Spit and Sputter
Ok The truck : 95 f150 standard cab, 300-I6, 5 speed
The Problem: when i first start out in first the truck falls on its face when i get going a little farther a cleas alittle but still sputters then when it finally gets up to speed it only spits and sputters past 1/4 throttle .... if i push the pedal down any further it runs like its getting no spark or no fuel let up and it clears up
What ive replaced: ignition coil (msd street fire)
Autolite pro wires
Autolite platnium plugs
Cap and rotor back in november
Fuel filter back in november
Any ideas guys ..any help is aprrciated
Old Mar 14, 2010 | 06:56 PM
ymeski's Avatar
Could be lotsa stuff. Error code scans. A wild guess would be your MAP sensor. Clean you IAC also. Usually if you disconnect the IAC while at warm idle, and it doesn't try to stall, it's pooched.
Old Mar 14, 2010 | 07:06 PM
Beastly_95's Avatar
no MAP and where is the IAC located ?
Old Mar 14, 2010 | 09:56 PM
ymeski's Avatar
No MAP? Then clean your MAF sensor w/ MAF sensor cleaner or Electronic contact cleaner (don't touch element w/ fingers). IAC's on air intake'/drivers side, looks like this:http://fordfuelinjection.com/?p=39
Old Mar 14, 2010 | 10:13 PM
Beastly_95's Avatar
**** sorry i miss read its no MAF ... im not used to all these letters for sensors and stuff im used to workin on old carb engines ... this is my first fuel injected truck with a problem
Old Mar 15, 2010 | 08:16 PM
ymeski's Avatar
So back to here.
Old Mar 15, 2010 | 08:36 PM
Beastly_95's Avatar
yes the truck is goin to have codes checked thursday ... i will try the iac tomora that is directly on top of the throttle body correct and i just disconnect the connecter....i tryed 3 different kinds of injector cleaners no luck with each ...it does it really bad when im at low rpm in 1st gear just starting out
Old Mar 16, 2010 | 03:09 PM
ycgoat's Avatar
Check for vacuum leaks, Put some good fuel cleaner in the tank and run for a few hours, and repair any faults found in the codes.
Old Mar 16, 2010 | 03:29 PM
ymeski's Avatar
Check fuel pressure. should have 50-55 psi.
Old Mar 16, 2010 | 03:35 PM
Beastly_95's Avatar
Ok i took IAC off at warm idle about 5 mins ago and all that changes was rpms went down but it did NOT try to stall stayed constant ......i put seafoam in last night.
Old Mar 16, 2010 | 04:09 PM
ymeski's Avatar
Mine's a bit more dramatic. What's your base timing set at? But right now my money's on low fuel pressure. Error codes scans & Fuel pressure test would help greatly. Save a lot of grief! Why waste time guessing & wondering.
Old Mar 17, 2010 | 05:35 AM
mohavewolfpup's Avatar
do these trucks have Throttle Position Sensors? maybe that's a part of the issue. Yank codes. on mine it was code 63
Old Mar 21, 2010 | 11:51 AM
Beastly_95's Avatar
I changed the 02 sensor, fuel filter, and checked all wires and plug-ins , and im running 93 octane in it now, the fuel filter was dirty but not all that bad ... havent pulled codes yet the local advance and autozone plus monroe muffler cant check OBD1 which is what i have soo... im still lookin and with my work schedule.... it sucks oo and ive tryed just about every injector cleaner on the shelp as well .... just trying to elminate possibilties
Old Mar 21, 2010 | 03:03 PM
ymeski's Avatar
http://www.handsontools.com/Equus-In...ol_p_5574.html or you can call around & find it in stores. $22.77/ OBD1 for fords 81'-95'. Digital numeric display w/memory & great manual.
Old Mar 21, 2010 | 08:22 PM
Beastly_95's Avatar
Thanks ymeski.... i bought that tool
