Spit and Sputter
I got the code scanner last night and i ran my codes which the process was easy as pie lol
Anyway here are the codes:
171
172
181
332
556
pretty much the trucks is running lean at part throttle and i have insufficient EGR flow plus a bad fuel pump relay(already replaced today)
171
172
181
332
556
171
172
181
332
556
171
172
181
332
556
try disconnecting the green vacuum hose going to the EGR and drive it. if that helps then test the EGR valve and EVP.
Unplug the Vac hose to the EGR. Have someone raise idle to 2K. If there is no Vac at the hose @2K, your EGR regulator on the other end of the hose is pooched! There should be no Vac at idle or WOT.
Ok i reset the computer then drove the truck and checked again and only 2 codes came up
172 (HEGO) HS02 sensor switch fault/lean
332 Insufficeint EGR flow
and i found that the tube that runs from the exhaust on top of the exhaust manifolds to the top of the engine not sure what it is, is broke off at the exhaust and there is air blowing out of the part on top of the engine out of 3 little holes ill try to get pics
ill check and try to replace the EVR today
ok more info .. i just ran a KOER test and here are the codes
41 R- HEGO (HO2S)sensor voltage low/system Lean
129 - Insufficient Mass Air Flow (MAF) change during dynamic response test....which my truck doesnt even have a MAF
167 - Throttle position sensor fault during dynamic response test
225 - Knock sensor fault during dynamic response test
311 - Thermactor air system/fault during engine run self test
332 - Insuddicient EGR flow detected
These are all after i reset the codes and i just put in a new EGR vacuum solenoid
You still haven't checked fuel pressure at the rail yet? Still haven't repaired the tube connection? Did you Rev the engine once during the KOER test? (that will get rid of a lot of the codes)
