302 Won't fire Help/ Command start?
Old Mar 1, 2010 | 04:45 PM
stowe44's Avatar
I just dropped a used 302 from a ltd in the f150 and it won't start! i narrowed it down to a prior command start in the ltd, is there anything from the ecu or any other electricals i need to remove? or if anyone has a installation manual? also they are both efi.
Old Mar 1, 2010 | 04:52 PM
stowe44's Avatar
sorry the command start is a cs3000
Old Mar 1, 2010 | 09:21 PM
ymeski's Avatar
Are you using the LTD's ECU?
Old Mar 2, 2010 | 01:44 PM
stowe44's Avatar
no i'm using the f150s. phoning a command start installer today cause i'm sure they will have a manual or something
Old Mar 2, 2010 | 05:30 PM
ymeski's Avatar
Run the LTD's! The harnesses & ECU should go w/ the engine.
Old Mar 17, 2010 | 07:36 PM
stowe44's Avatar
Can someone tell me quick where the ecu is located on this truck!!
Old Mar 18, 2010 | 12:47 PM
ymeski's Avatar
Usually behind the left or right side kick panels. Start w/ drivers side next to the E-brake.
Old Mar 26, 2010 | 08:32 PM
stowe44's Avatar
Okay replaced the Ecu, still no luck, truck will turn over all day, it seems there is no power getting to the fuel pump? could it have something to do with the command start? I'm not getting any power to the inertia switch anyone have any other solutions?
Old Mar 26, 2010 | 08:53 PM
ymeski's Avatar
Run a KOEO (key on engine off) Error Code scan. The PCM relay actuates the F/P relay. And you know what the F/P relay does!
