1993 F-150 I-6 missing and bucking and 1/2 throttle
Old Feb 20, 2010 | 08:50 AM
jspec's Avatar
I have had this happen once before the last 2 weeks but it seems to keep coming back. It doesn't seem to matter if it is cold or warm and there is no real consistency in when it happens. At 1/4 throttle it runs fine I don't get any sputtering or missfiring. And at full throttle it seems to just over power whatever is going on. At 1/2 throttle everything just shakes. It feels like it is running on 2 cylinders. No power. Also today I thought I smelled gas after this happened like it was flooded? I was going to change the plugs and wires but I doubt that is what it is. The truck has 86000 miles on it if that helps. I shot a few videos today so I think you can hear it. Please tell me what to check?
http://www.youtube.com/watch?v=UZPjt_kZdDg
http://www.youtube.com/watch?v=-oln3lDybmM
http://www.youtube.com/watch?v=OEhoeL1NlRU
Old Feb 20, 2010 | 10:18 AM
jspec's Avatar
http://www.youtube.com/watch?v=vTsiNRIgLmI
Old Feb 20, 2010 | 06:38 PM
Filmy's Avatar
I'd start with fuel pump and/or filter first.
Old Feb 21, 2010 | 12:46 PM
gdusek's Avatar
Like Filmy said I'd replace your fuel pump and I'd double check plugs and plug wires since they're cheap. Also do your cap and rotor while you're at it. I had a little sputtering in my acceleration and replacing my cap/rotor/plugs/wires just the other day got rid of it.
Old Feb 21, 2010 | 01:28 PM
jspec's Avatar
Well it happens with both tanks so I was thinking that wasn't it. I would say fuel filter but it is so random I doubt that is it. Plugs and wires look OK. I think this is more sensor related. I tried to read the codes but I do not understand the blips on the voltmeter in the video above.
Old Feb 21, 2010 | 01:32 PM
gdusek's Avatar
I'm not really sure what to tell you about the codes that kept popping up, not sure how you were getting those without anything running.
Old Feb 21, 2010 | 09:52 PM
jspec's Avatar
I did a self test. The voltmeter is just replacing the check engine light as my light is burned out.
