changing oil in a truck that has 6 year old oil in it
Old Jan 14, 2010 | 11:42 PM
bankrpt's Avatar
What do I need to do besides draining the oil and changing the filter? Is there any thing I can add to the oil to help clean all the old oil out. Thanks Jonathan
Old Jan 14, 2010 | 11:44 PM
Paralyzer's Avatar
drain the oil and change the filter. then add a 50/50 mix of clean engine oil and Auto trans fluid. Let the engine idle for 30 mins then drain and change the filter again. Fill with oil of your choice.
Old Jan 14, 2010 | 11:45 PM
1clean42's Avatar
Please don't tell me this is in your show truck :o
...is there a way to drop the oil pan?
Old Jan 14, 2010 | 11:53 PM
bankrpt's Avatar
No its not lol its a old 79 ford f150 I picked up. paralyzer so if it holds 6 qts do 3 qts oil and 3qts trans oil like atf? What does the trans fluid actually do brake down the sludge? Will it smoke really bad?
Old Jan 14, 2010 | 11:56 PM
Paralyzer's Avatar
you bet. ATF is full of detergents and does a great job at this. it wont smoke anymore then it would with just engine oil.
Old Jan 15, 2010 | 12:00 AM
bankrpt's Avatar
Ok thanks do you know exactly how many qts a 302 holds is it 5?
Old Jan 15, 2010 | 12:03 AM
thejake1989's Avatar
would seafoam work for this also? i know you can add it to the oil systems as well
Old Jan 15, 2010 | 12:05 AM
Paralyzer's Avatar
im pretty sure the 302s are 6 with a filter change
Old Jan 15, 2010 | 12:06 AM
bankrpt's Avatar
Ok thanks a lot
Old Jan 15, 2010 | 12:11 AM
Paralyzer's Avatar
im not a fan of seafoam products, maybe as an intake/valve cleaner but the idea of dumping something with the texture of water in an engine does not sit well with me. The ATF trick has been around for decades and works very well.
Old Jan 15, 2010 | 12:14 AM
bankrpt's Avatar
After I do this little trick what kind of oil would you go back with something like a full synthic or what
Old Jan 15, 2010 | 12:18 AM
Paralyzer's Avatar
older vehicles use alot of cork or other textured seals. using sythetic can actually draw deposits out of these seals and cause a leak. id just use Regular oil 10w30 or 5w30 in a colder climate.
Old Jan 15, 2010 | 12:19 AM
bankrpt's Avatar
ok thanks you have been a great help
Old Jan 15, 2010 | 12:21 AM
Paralyzer's Avatar
no problem!
Old Jan 15, 2010 | 12:31 AM
ill second using ATF, If its really bad you could do a second treatment of another 30-45 minutes if you have time, and have the funds to go through that many quarts before the final oil fill
just as a reminder you dont want to change the filter until you are done with the ATF, then put a fresh filter on for the fresh oil
