winshield washer fluid motor
Old Jan 8, 2010 | 04:47 PM
riverrat10's Avatar
where is the washer fluid motor located? i dont think mine is working
Old Jan 9, 2010 | 03:02 AM
masseyman's Avatar
It should be at the bottom of the washer fluid tank.
Old Jan 9, 2010 | 06:07 PM
S-crew03's Avatar
They are real simple to replace, the motor/pump can be bought at any pep boys/autozone/Napa....
Old Jan 9, 2010 | 07:52 PM
FordGuy24's Avatar
If you pull that fluid tank out there should be an opening at the bottom and the motor is sittin inside...not hard to replace
Old May 24, 2011 | 04:51 PM
kolodej's Avatar
I have a 93 and cant get my washer to work, if I put 12 volts to the pump it will work ,and when I press the button on the stalk I hear a click under the glovebox but washer wont work, any sugestions?
Old May 24, 2011 | 08:29 PM
Steve83's Avatar
Unplug the WCM and apply 12V to the Bk/Wh wire (pin #4). If the pump sprays, replace the WCM (#32 in this diagram).
Old Oct 12, 2011 | 09:11 AM
kolodej's Avatar
Thanks, it was the factory butt connector on the black wire at the pump.Visually good waterproof connector but broken
