95 F150 Pressure Switch circuit failure open
Hi, I just replaced my TPS sensor and now receive a obd 1 code 62 --AXOD 4/3 Pressure Switch Circuit Failed Open. Can't seem to find any info in the book. Help Pkease, Truck wil not turn over now.
mj zorad
mj zorad
It is 5.0 automatic. After replacing the tps the truck started. I moved it. turned off engine then it would only start if petal was to the floor. Then drove it a up and down the road. And turned off the engine. After that it would not start the engine turns over but nothing more, Is it possible that I need to reset the computer to erase all codes then if it starts drive truck around.
mj
mj
That code indicates an internal failure in the transmission.
Reset the PCM and retest. If it shows up again then there are two possibilities: an internal problem with the tranny or an external problem with the wire harness. Neither has squat to do with the TPS.
