Front Turn Signals on 1993 F250
Old Dec 1, 2009 | 07:00 PM
08stx4x4's Avatar
My 93 F250 plow blew one of the front turn signal bulbs and I'm trying to change it and having no luck in doing so. I can't figure out how the hell the thing comes apart. I've removed the 2 screws on the top but I can't seem to get the actual turn signal/parking lamp fixture to come loose.
The only other screw I can find is not even an option because it's covered by the front fender and nobody could possibly get a screwdriver in there to hit it.
If somebody could please tell me how this tings comes apart that would be great.
Thanks.
Old Dec 1, 2009 | 09:00 PM
adrianspeeder's Avatar
Easy to take off the two other nuts holding on the TS assembly. They are down below the headlight on threaded studs from behind the lens that point to the rear of the truck.
Adrianspeeder
Old Dec 2, 2009 | 11:35 PM
Steve83's Avatar
Use a 7/16" (11mm) deepwell socket. You may have to move the battery or overflow reservoir for access. If you pull the reservoir, do this:
Old Dec 3, 2009 | 02:38 AM
andrew_516's Avatar
I had to do this just the other day. there are two screws hidden inside. one is located right next to the large bottom light and the other is located next to the light under the turn signal one. i think these are the running lights?? anyways, you have to feel them with your finger and get a socket in there. it is by far easier if you take out the resivior or battery to do this.
i can get a picture of exactly where there are if you cant find them
