Proper way to disengage 4wd (auto hubs)
Old Aug 29, 2009 | 08:18 PM
Dan71's Avatar
Today I had to put my truck into 4wd to move a trailer and my rear was spinning on wet grass. After I moved it out, put my truck into neutral and went back to 2wd. I noticed my right wheel still felt like it was engaged and it never did that before.
Had my rotors installed not too long ago and I had them look over the auto hub inners to make sure it was all ok. He told me everything looked good and he just greased it in there.
Before, I use to take it out of 4wd and drive away. Today after it was still engaged, I backed up about 10 feet, seems to be fine now.
So is that normal or is something not right?.. and what is the proper way to disengage 4wd?
Thanks!
Old Aug 30, 2009 | 10:34 AM
Steve83's Avatar
Read the sticker on the back of your sun visor, or the owner's manual. If you don't have one, download it from Ford.
https://www.fleet.ford.com/maintenan...ls/default.asp
Old Aug 30, 2009 | 01:36 PM
shifty_85's Avatar
that is the proper way to disengage. you put it in neutral click 2wd back up about 5-10 feet and turn the wheel to the left. and that should disengage it.
Old Aug 30, 2009 | 09:38 PM
stealthsniper96's Avatar
for 4 high you dont even need neutral. just hit the brake and throw it back into 2. thats how i do it and it works fine
