How much difference will I notice?
Old Jul 22, 2009 | 06:10 PM
Alkoholik's Avatar
I ordered a hypertech power module and cold air intake for my 1995 f150 302. How much of a difference do you think will I notice in power?
Old Jul 22, 2009 | 06:24 PM
StrangeRanger's Avatar
You'll "notice" a lot more than you'll ever measure. It's the nature of the human brain. you buy something and install it and you're convinced that it is just the feline's posterior. Take it to the drag strip and you're 0.02 quicker in the 1/4 at 0.1 MPH higher trap speed. (You won't "notice" nearly as much performance gain after you see the first timeslip)
Old Jul 22, 2009 | 06:56 PM
Matts ford's Avatar
i have the hypertech chip and i didnt notice anything really. its just a little bit smoother while accelerating but its not quicker than before. and throttle responce did get a little bit better but thats about it. all it does is advance the timing a little bit. and its suppose to change the shift points on electronically controlled trannies.
Old Jul 24, 2009 | 09:28 AM
2004f1505.4x4's Avatar
If I were to do a chip i'd go superchips. "apperently" in there 91 octane setting you can notice a diffrence(i've herd).
Old Jul 24, 2009 | 01:38 PM
GTRider245's Avatar
Chips for pre-97 1/2 ton trucks are useless. You can do the same thing with a socket set and a timing light. Dont buy into the hype.
Aftermarket intakes are just as uselss. Dont waste your time.
Old Jul 30, 2009 | 12:11 PM
Steve83's Avatar
Like S.R. said: you'll notice as much as you can imagine.
Read the RESULTS pages:
http://www.performanceunlimited.com/projectmpg/
