Crankcase Positioning Senser
I recently bought a 96 F150,4.6Liter 6cyl with 5sp trans.and trying to get it through inspection.I'm not gonna say how much money i've spent attempting to get the CEL to go out but believe me i'm broke for the next two months.Codes say I need a CPS and I need some feedback on how the wire disconnects from the sensor and how to replace it.Thanks for your anticipated help.
Crankcase Position Sensor
Thanks for responding to my tread Ranger.My 96 F150 is a early modal.Made in
January 96.It must be the 4.9.Do you have any info about changing the Crankcase pos. sensor? The CEL is on all the time and the CPS is the only code
being tossed out.
being tossed out.
Ckp
[QUOTE=hothand45;3751410]Thanks for responding to my tread Ranger.My 96 F150 is a early modal.Made in
January 96.It must be the 4.9.Do you have any info about changing the Crankshaft pos. sensor? The CEL is on all the time and the CKP is the only code
being tossed out. As you may have guessed I'm a rank amateur at auto repair and appreciate the lesson.Kinda new that the crankcase did'nt turn though.
Assuming that you do have the 4.9 inline 6:
Technically there is no CKP in the 4.9. It reads the crank position indirectly by reading the PIP (Profile Ignition Pickup) sensor in the distributor.
What exactly is the code you are getting?
