Considering a new project, what is a 1973 F100 4x4 worth?
Old Feb 22, 2009 | 11:30 PM
freekyFX4's Avatar
I found a 1973 F100 4x4 that is pretty complete. The guy is asking $1400 OBO. How much is the truck worth? What should I look for when I go to drive it? Body is pretty rough but the truck runs really well. Not sure which engine, but 4wd works and it has a manual 4sp with granny low transmission. I don't know much about these older trucks. Any input is appreciated.
Old Feb 23, 2009 | 07:34 AM
bigbronc's Avatar
That is probably not a bad price and could be talked down most likely. Truck also probably has an FE engine either a 360 or 390. Not the best for fuel mileage, but will pull down a house. And keep the driveway from rusting from the oil leaks. Drivetrain is pretty much bullet proof with a solid axle Dana 44 up front and a 9 inch in the rear. 73 should have disc brakes on the front. Not sure if the t-case is a 203 or 205 gear drive. The 203 is aluminum and you can't mistake it for the 205 gear drive unit! Good luck.
Old Feb 23, 2009 | 08:06 PM
freekyFX4's Avatar
Thanks for the info. Those old trucks really are indestructible, aren't they?
Old Feb 24, 2009 | 02:40 AM
bigbronc's Avatar
Yep, got a 79 out back that my buddy's dad bought new. It now sports 40in
Monster Mudders, 302 with a granny gear, and 4.11 axles.
Old Mar 9, 2009 | 08:59 AM
Dan71's Avatar
Good luck if you decide to buy your project. http://www.lmctruck.com has a ton of parts for the '73-'79 F series.
*** POST PICS!!!!!!!! (if you get it)
