Engine swap to an 83
Old Jan 18, 2009 | 02:38 PM
bruce.aj's Avatar
I was wondering if I could swap a 351W EFI from a 88 Econline into my old 83 f-150, I have a 351W in there now but it's completely worn out. Thanks in advance.
Old Jan 19, 2009 | 06:59 AM
bigbronc's Avatar
No problem, but I would retain the carb instead of trying to use the EFI unless you know what you're in for. Fuel system upgrades, wiring, pcm, etc. The basic engine is the same.
Old Jan 21, 2009 | 03:00 AM
bruce.aj's Avatar
Ok, it has a dual fuel carb... I kinda wanted to get rid of that with out buying another carb. I imagine I could find one for cheap.
Old Jan 21, 2009 | 08:46 AM
bigbronc's Avatar
Is it a 2 or 4 barrel? If it is a 2, you can replace it with a regular Motorcraft 2 barrel from almost any older engine. If it is a 4 barrel, put a Holley 600 on it. Wait, do you mean the variable venturi? If so, you may have an early EEC 3 system. Which means you also need to install a Duraspark distributor and Duraspark ignition module that bolts to the fender. This will be better in the long run anyway, due to the fact that the EEC 3 system had many problems. Let me know if you need more info.
Old Jan 21, 2009 | 07:08 PM
bruce.aj's Avatar
I'm learning what I can because I'll be doing this in the summer, I'm not too sure about the carb it self... I pull a cable and it switches between fuel... I'm gonna stick my neck out and say that it's two barrel. I'm not looking performance at all, I need to repair my truck for next winter time so I have one in case I need it running... My S197 is too little to do anything usefull except get groceries and well women...
