Another dual question
Old Jun 6, 2001 | 10:06 AM
nate955l's Avatar
Post Another dual question
I'm planning a custom dual exhaust and I have one question. It will be after the cat and i was wondering which would sound and perform better. Y pipe then 2 mufflers or 1 muffler then Y pipe.
Nate
Nate
95 XLT 5.0/4r70w/3.31
SC SB 30X9.5's
Perfomance Cover Tonneau
Ventshades and Bugflector
Chrome Bedrails
Old Jun 18, 2001 | 09:17 AM
primetime's Avatar
Cool
Depends on what you are looking for, but I'd go with y-pipe then two mufflers - more flow.
Old Jun 21, 2001 | 02:13 AM
dvldog458's Avatar
Post
I agree with Primetime
More flow more power!
http://hometown.aol.com/dvldog458/myhomepage/auto.html
Old Jun 21, 2001 | 10:30 AM
max mitchell's Avatar
Cool
One muffler of similar design is louder than two. One high flow muffler can outflow two average flow mufflers. There are high flow mufflers that have way more flow than necessary to get the power out of that combination. If you go with the typical HP muffler, flowing approx. 400cfms., you may get more performance running two mufflers (if you had 2 pipes). Most of these points will be moot if you don't run "true duals" anyway, your flow will be limited by what feeds either setup; one single pipe (usually 2.5"). The first forward restriction limits everything from there back.
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 4.10LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Pirelli Scorpion Zero 275/60/16s, Mobil 1, K&N oil filter.
[This message has been edited by max mitchell (edited 06-21-2001).]
