Need advice with 1992 Truck
I have a 1992 F-150 302 extended cab pickup with 95,000 miles. I have always performed all schuduled maintanance. It seems to use one quart of oil every 3000 miles, with no signs of smoke, and no leaks. Is there anything I can do besides a complete rebuild? Thanks
Orlando,
That oil is going somewhere. You need to find out where. The obvious spot to look first is every sparkplug. The other is the radiator (real easy). Beyond that I would look to a good tec guy. Without knowing what is happing to the oil, you could end up speending 1000's on what may be a simple solution.
R.
R.
I think if if it is only using one quart of oil every 3000 miles you have nothing to worry about, your truck is 9 or 10 years old and has 95K miles on the motor, if there are no obvious signs of leakage in the radiator or out of some type of a seal you have nothing to worry about.
I don't really think there is anything to worry about either , that sounds like normal consumption , my 91 chevy 1500 witha 350 , has 219,800 miles on it , it has never had internal work on it , and it uses a quart every 3200 miles .
Try changing the breather on your valve cover or replace it with a stand alone style so it's not vented into the airbox.
97 F150 Flareside Ext Cab
XLT,4.6 Auto,DK Toreador Red,Ford Signature Atlas rims
275/60 17 Yokohama AVS ST
3:73 LS,K&N Fipk
Superchip,Flowmaster Force II,Ford 9mm wires
Bosch Platinium +4
MAAP SS step bars
3:73 LS,K&N Fipk
Bosch Platinium +4
MAAP SS step bars
Orlando, no issues with that truck. Mine burns that in an oil change interval. You have nothing to worry about.
Have Fun & Keep on Truckin'
Dean
1994 F-150 XLT Supercab, Long Box, 302 EFI, 3.55 LS, Superchip, K&N FIPK, Bosch Platinum +4 Spark Plugs, Automatic, Single Catalytic converter, followed by a Raven Z-55 muffler and finished off with chrome tips (2 1/2" to 3"), Royal Blue in and out, Captain Chairs. Chrome Rims 15x8's, BFGoodrich Radial T/A's 107S 275/60R15 (Summer), OEM Aluminum Rims 15x8's, Michelin LTX M/S 108S (Winter), Lightly Tinted, Soft Tonneau Cover, Ford Receiver Hitch Cover & Lock, J&J Enterprises Stainless Steel AirDam with KC driving lights, Lund Supersteps, Lighted Grab Bars, VTech Slotted Taillight Covers, Alpine CDM-7829 Head Unit, PPI 4800 Amplifier, Kicker 10" Solo Baric Sub with Custom Box and Kicker Impulse 6.5 Mid & Tweets.
Dean
I have to agree. 1 quart after 3000 miles is no big deal at all. I had a '91 Ranger with the 3.0 Liter engine that did the same thing. I had it for about 100,000 miles over about 4 years and it used that quart in 3000 miles in the beginning to the end. Never got any worse. Hey man think of it as 12,000 miles per gallon!!!
