new to the board need advice
WANTED TO SEE IF ANYBODY HAD ANY IDEAS ON HOW TO LEVEL THE FRONT END OUT. I TRIED TO FIND 2" COIL SPRING SPACERS BUT NO LUCK. ANY IDEAS WOULD BE HELPFUL.MAIN REASON BEING TIRE CLEARANCE.
1991 F-150 4X4
6" SUPERLIFT
3" BODY
38.5X16.5X15 SUPER SWAMPERS
[This message has been edited by MCELROY4X4 (edited 03-29-2001).]
1991 F-150 4X4
6" SUPERLIFT
3" BODY
I don't have the answer to your question ,but you may be able to help me. I have a 92 F-150 with 35x12.5 tires and I keep on blowing the orginal 8.8 rear out . I was wondering since you are running bigger tires then me you might have the same probelm . If you are what did you do to fix it.
<font face="Verdana, Arial" size="2">Originally posted by MCELROY4X4:
1991 F-150 4X4
6" SUPERLIFT
3" BODY
38.5X16.5X15 SUPER SWAMPERS</font>
1991 F-150 4X4
6" SUPERLIFT
3" BODY
<font face="Verdana, Arial" size="2">Originally posted by b gloss:
I don't have the answer to your question ,but you may be able to help me. I have a 92 F-150 with 35x12.5 tires and I keep on blowing the orginal 8.8 rear out . I was wondering since you are running bigger tires then me you might have the same probelm . If you are what did you do to fix it.</font>
1989 F-150 XLT Lariat: 2WD 302 5spd[*]Performance Accessories 3" Body Lift[*]33x12.50.15 BFG on 15x10 AR Rims[*]Rancho Steering Stabilizer[*]Rancho RS 5000 Shocks[*]K&N Air Filter[*]Straight Pipes For Now...
Muffler? I don't need no stinkin' muffler!
b gloss
what gears are you running in the rear?I had to change mine out to 4.56.also about how long are they lasting?what type of lift did you put on?
1991 F150 4x4lwb
6" suspension lift
3" body lift
38.5x16.5x15
1991 F150 4x4lwb
6" suspension lift
3" body lift
38.5x16.5x15
