Damn fuel filter!!!!!!!!
Old Mar 16, 2001 | 08:35 PM
STDRILLER's Avatar
Question Damn fuel filter!!!!!!!!
Hey Dudes.
I want to change the fuel filter on a '94 4.9L.How do you remove the old one?
I pulled like hell on it but can't seem to loosen it.(yes, I removed the clips)I don't want to damage the fuel line, so I didn't try to pry it loose.
And there are 2 plastic clips in the filter box. Do I need those?
94 F150 4.9L, FIPK, CHIPPED, More later(cash willing)
Old Mar 16, 2001 | 11:37 PM
Nomopar4me's Avatar
Post
there is aspecila tool to remove it. YOU MUST HAVE THE TOOL. I hope you have not ruined the fittings by tugging on them. They are easily ruined. As for the plastic clips, you probably have the wrong filter. The FG-800 is not what you eant, you need an FG-872. It has longer fittings that allow the lines to be properly attached and removed.
Old Mar 17, 2001 | 08:13 PM
JOHNNY MC's Avatar
Post
Yeah, the tool needed is a K-D 3321, which is available at most auto parts stores for about $12.00. You'll use the smaller 5/16" end. And Nomopar4me is correct about the filter. You'll want to use the filter with the longer nipples. Using the shorter fitting will work, but the next time you go to change it, you can't get the special tool up on the fitting, which causes you to cut into the filter end(a BIG mess)to make a connection. I also advise to wear eye protection and bleed the line pressure, before starting. And of course, no smoking, dah! Hope this helps & good luck!
1993 F-150 4x4 5.0L EFI 5spd. Silver Shortbed..Kelly Safari AWR tires,K&N Air filter,Cat-Back Exhaust.
Old Mar 19, 2001 | 11:12 PM
STDRILLER's Avatar
Post
Thanks guys.The filter looks right and the #'s cross reference correctly.I will look at it closely when I remove the old one to see the ends are long enough.The fittings aren't leaking so I don't think the tugging hurt the lines.And my brother in law is a grease monkey,and may have the tool.Thanks again
[This message has been edited by STDRILLER (edited 03-19-2001).]
Old Mar 19, 2001 | 11:17 PM
fordtec2001's Avatar
Post
ford has the retainer clips if you need to replace them if the filter wont come off then you'll need to cut the filter ends off and replace the retainer inside the lines themselfs
