broken bolt..HELP!!
I broke a @#%&*@ bolt while putting on my water pump. it was the one that also helps hold up the air conditioner asembly also. it snapped right where the threads start so the is about an inch or so of it in there...can it be drilled out or what???
95 F150 ext cab 4x4 orp
164,000+ miles 351
straight pipes (still not loud enough)
splitfire plugs
performance wires
31x10.50x15 grabbers
rough country shocks
tinted windows
ranch hand bumper
custom front bumper
100w rally lights
crome bed rails
autovox alarm
50 watt reverse bulbs
BAD BOYS BAD TOYS
164,000+ miles 351
splitfire plugs
performance wires
tinted windows
ranch hand bumper
custom front bumper
100w rally lights
crome bed rails
autovox alarm
BAD BOYS BAD TOYS
Whenever I break bolts, first I would try to weld a nut on the end of the bolt thats sticking out. If not you can buy bolt removers at a auto store. These are called easy outs. you will need to drill a hole in there, then tap the easy out in, then get a vise grip on there and turn it out. The instructions are more clear in the package. hope this helps
An easy out should do it for you. The logic in this doesn't make sense but they usually work.
Worst case if the easy out doesn't work is to carefully drill it out and re-tap to a new bolt size.
