speed density conversion
Old May 24, 2000 | 09:18 AM
Jetter's Avatar
Question speed density conversion
Has anyone ever done or does anyone know of a conversion kit for speed density to mass air? Maybe there is there a performance upgrade for the speed density? I have a 95 5.8 and am in the process of installing JBA headers and Gibson single side cat-back exhaust and I'm interested in freeing up on the intake side also. Anyone know of anything or have any ideas?
Old May 24, 2000 | 05:02 PM
Pastmaster's Avatar
Post
I think there are several aftermarket companies that make conversion kits. I know Motorcraft has one, that runs about 600 bucks. Really if you don't have any serious mod plans in the future it isn't worth it,
Old May 24, 2000 | 05:29 PM
Jetter's Avatar
Red face
Other than the headers and cat-back I was thinking of maybe chipping it. With the new exhaust setup getting the air out of the engine I would really like to improve on the intake side, but $600 sounds a little steep. Thanks for the input though.
Old May 24, 2000 | 09:13 PM
signmaster's Avatar
Cool
I've seen conversions advertised, but they are not cheap. As far as intake mods go, it seems that there aren't many to fit the 95s. I have a 95 with the 302 and got a good boost with massive drilling of the lower airbox section. I left the cold air tube on because it helps to block heat coming from the exhaust manifold area.
Old May 24, 2000 | 09:34 PM
StrangeRanger's Avatar
Post
If you're not going to change the cam, raise the compression, or rework/replace the heads you probably won't need to convert to mass air. Moderate exhaust mods, an FIPK, pulleys and a chip are all S/D compatible. MAF in itself doesn't increase your HP, it simply allows you to do a greater variety of mods without screwing up the EFI controls
According to a couple of people I've talked with, even the 1.7 roller rockers will work with S/D. If so, that's a bolt on 10-15 rear wheel HP.
Old May 24, 2000 | 10:49 PM
Pastmaster's Avatar
Post
Hey Strange: Do you know what the largest cam you can run in a Speed Density 302? Would it be much larger than factory?
Old May 25, 2000 | 05:32 PM
Post
I don't have a clue. E-mail Crower and ask them, they're real good about responding to questions, and make nice camshafts too.
