Replacement Battery
Old May 12, 2000 | 10:05 AM
insect2's Avatar
Post Replacement Battery
If you ever need to replace your battery get this one from Auto Zone. (No I dont work for them).
The "Duralast-Gold" 34DT-DGS fits my F-150 and it has A THREE YEAR FREE REPLACEMENT. This is much more that anyone else. Made by Johnston Controls.
According to battery information you should buy the battery that offers the longest free replacement because they couldnt offer free replacement unless they were very well made.
Johnson Controls also makes many other brands of batteries like DieHard etc. But the Duralast is the only battery with three year free replacement. Not prorated.
Check out the web site Johnson Controls.
[This message has been edited by insect2 (edited 05-12-2000).]
Old May 12, 2000 | 04:20 PM
Pastmaster's Avatar
Post
Do you know what the cca's were for it? My mom has a duralast in her suburban. I like the handle!
Old May 12, 2000 | 05:35 PM
insect2's Avatar
Talking
Pastmaster: The CCA depends on the model you get. The particular model I referenced has cranking amps of 935 and CCA of 750, with a three year free replacement.
Old May 12, 2000 | 09:45 PM
Mike Lewis's Avatar
Post
Isn't there some rule about getting a battery sized according to your engine size? Thought I'd seen that in a Chilton's...
-Mike
Old May 13, 2000 | 09:07 AM
insect2's Avatar
Talking
Hello Mike: Yes, you need to get the highest CCA in the size that will fit in your battery box. When you get ready, open your hood and sketch your battery with the plus and minus post and measure the size, height, depth, and width. Be sure to indicate where the two post are located.
Also most suppliers have charts that will show the normal replacement battery number.
If you let the store install your new battery then you dont need to make a sketch.
Also, visit http://www.johnsoncontrols.com
There is a lot of battery information there.
[This message has been edited by insect2 (edited 05-13-2000).]
Old May 13, 2000 | 08:05 PM
Sycoholic's Avatar
Cool
As a rough guide, go with twice the engine displacement in c.i. Example, a 302 would require roughly a 604 cca battery. Any more cca's and the battery will last longer and not have to work as hard. Any smaller, and it won't last as long and will work harder.
Remember, it's just a rough guide. A little smaller won't hurt, and bigger is always better.
1997 F-150, 4.6, automatic, Dark Toreador Red, Supercab, Flareside, 4X4 Off-Road, Towing Package, Ford hvy dty rubber floor mats, Kenwood 10-disk cd changer, Kenwood am/fm cassette head unit, Ford bugshield, Chrome Grizzly Wrap Around Push Bar with 2 KC 100w Daylighters, Ventshades, Ford bedliner, Lund Premier tonneau cover, cab and bed professionally undercoated, Code Alarm Sure Start RVS remote starter, Ford alarm, Realistic CB with Wilson Little Wil antenna and Astatic power mic, ported MAF sensor, and Lots of TLC!! (Besides being an F-150 nut, I am a Ford auto technician.)
Old May 15, 2000 | 03:36 PM
Pastmaster's Avatar
Post
I can't remember what the factory one was, But I run 850 now, and haven't had any problems yet. Do you guys know who the provider is for the motorcraft battery's?
Old May 15, 2000 | 07:06 PM
insect2's Avatar
Talking
Pastmaster: Johnson controls makes the Motorcraft battery.
Old May 16, 2000 | 07:52 PM
Mike Lewis's Avatar
Post
Thanks for the information. I will have to check into this!
-Mike
