Low Oil Pressure!
Old Apr 17, 2000 | 10:11 AM
MWKellner's Avatar
Unhappy Low Oil Pressure!
In my 1996 F150, 5.0 I always begin with good oil pressure (right in the middle). After driving 20-30 minutes on many occasions the pressure will fall to the very low end of the normal range. I have never done anything because it was still in normal (barely). Yesterday the same thing happened, BUT the needle fell well below the normal range to the L. This was the first time that it has gone below normal; I HOPE!
While the oil pressure was low the temp gauge did not rise. Does this mean that the oil was really flowing and the gauge was broke? or will the oil keep the engine somewhat lubricated even if it is not pumped? And the last question would it be OK to drive to the dealership (10 miles) or should it be towed? Thanks -- Martin
Old Apr 17, 2000 | 01:55 PM
MWKellner's Avatar
Post
Thanks Johnny MC,
that was very interesting, I just hope that mine is only an electrical or gauge problem.--Martin
Old Apr 18, 2000 | 12:00 AM
JOHNNY MC's Avatar
Post
Hey Martin..It appears Ford started to put in bogus oil pressure indicators around 86' or 87' to keep complaints and warranty work to a minimum. Go to the Engine forum and do a search for oil pressure gauge and read what some others have found out and have said. It was an eye opener for everyone including myself.........Les
1993 F-150 4x4 5.0L EFI 5spd. Silver Shortbed..Kelly Safari AWR tires,K&N Air filter,Cat-Back Exhaust.
