gear ratios
Old Apr 1, 2000 | 01:41 PM
insect2's Avatar
Cool gear ratios
Hello: I have a 1996 F-150 4 x 2, 5 speed manual transmission.
My question is : what is the engine RPM when driving the highway in overdrive 5th gear at 60 mph? I have 3.08 rear end.
Hope someone can help.
Thanks in advance.
[This message has been edited by insect2 (edited 04-01-2000).]
Old Apr 1, 2000 | 08:09 PM
Pastmaster's Avatar
Post
My guess is you don't have a tach. I have a 93 with a 302/e40d and 3.55ls gears. I run at 1800rpm@70mph. I would guess you would run somewhere between 1500-1800 at 70mph. And I would guess you would run at 1400-1700 at 60mph?
Old Apr 1, 2000 | 09:56 PM
StrangeRanger's Avatar
Post
Assuming you have 235/75-15 tires, and a 0.80 OD ratio, you're turning about 1775 RPM at 60. Makes ya want to run right out and buy a 3.55 don't it?
Old Apr 2, 2000 | 11:59 AM
insect2's Avatar
Smile
Thank you for the information. I do not have a tach in my truck.
So if I am running about 1500 aprox rpm at 60 mph, in 5th gear, then this engine is just loafing - right?
Thanks for the information.
Old Apr 3, 2000 | 12:05 AM
Pastmaster's Avatar
Post
It should just above idling. Which is good for mileage. But bad for hills.
