Computer code help
Old Jun 16, 1999 | 09:01 AM
4x4Ranger's Avatar
Computer code help
The check engine light on my 93 F150 with the 4.9L 5spd is on constantly. It comes on about a minute after you start the truck and stays on until you shut it off...it runs fine though. I ran the codes and got these two, 327 and 332. Does anyone know what they mean? The Haynes manual doesn't list them. Thanks!
1994 Ford Ranger 4x4 4.0L
Old Jul 5, 1999 | 09:48 AM
fordfan's Avatar
hey ranger, try posting this under the topic Engines more people in there
1989 F-150 XLT LARIAT 4x4 4.9L I6 5 speed manual tranny 3.55 gears K&N FIPK 3" Flowmaster.I will soon add a 4" lift and 33"tires and other mods too numerous to put here.
Old Jul 17, 1999 | 11:13 AM
nomo's Avatar
Post
It's probably too late, but here they are:
327- EGR Valve Position (EVP) sensor, Pressure Feedback EGR (PFE) sensor or EGR Pressure Transducer (EPT)- signal voltage too low.
332- Insufficient EGR flow detected.
Neal
Old Feb 22, 2000 | 10:00 PM
4x4Ranger's Avatar
Post
I thought I'd bring this topic back up since there seems to be a lot more people in this forum now.
Anyway the light is still on I havn't really played with it. Here's the background of the problem. The check engine light would come on briefly as I'd be driving down the road...maybe stay on for 1-5 minutes. This bugged me so I checked the codes and it said insufficient egr flow or something like that (its been a long time). I replaced the EGR valve, then the light was on constantly after about a minute of driving. I then also replaced the sensor on the EGR and that didn't do anything.
Anyone have any ideas what is causing the light to go on?
1994 Ford Ranger 4x4 4.0L, K&N, Superchip, 63mm T-body
1993 F150 Ext. cab 4.9L 5spd 4x4
Old Feb 25, 2000 | 05:51 AM
nailer's Avatar
Talking
4X4Ranger, You may have a vacuum leak, check all hoses. Also you can do a vacuum drop test if you have a vacuum guage/pump ($25.00 at parts store). EGR valve is vacuum controlled, if you are not getting enough it will call the sensor/valve bad.
Also the rule is, to run the Key ON Engine Off (KOEO) test till all codes are clear. After that run Key On Engine Run tests(KOER). KOER tests are dynamic. They can be real sensitive run a few times at different temps (i.e. Morning, noon, and night). Rember to bring Engine up to full temp. O2 sensor needs to see full temp.
Hope this helps
-----nailer-----
ON ORDER: 2000 F250 SD SC XLT V-10 SB With all the goodies! (Due Mid-April)
CURRENT: 1993 F150 SC XLT 5.0L V-8 with 160,000 miles and lots of great memories!
Old Feb 25, 2000 | 05:57 AM
nailer's Avatar
Wink
4X4Ranger, Follow my post to Mike Lewis under "Check Engine Light". This Forum. The web site will give you a full list of 2 and 3 digit codes for the Ford EEC-IV system.
Old Feb 27, 2000 | 10:24 AM
4x4Ranger's Avatar
Post
Thanks nailer! I'll give that a try.
-Adam
