Runs Rich
I have an 89 F-150 with a 300 I-6 EFI with 185,000 miles. I have been getting a code that says it is running rich, and mpg has dropped a bit. There has been no noticable drop in power, and it burns no oil at all between changes. Since it is fuel injected, I don't think there is any way to lean it out. This only started after it got real cold. I put in 5 new plugs recently, one seems to be welded in. It sounds fine, no skipping or anything. The other plugs looked alright when I took them out, just old. I am thinking about trying to get the other plug out, and then add an MSD or Jacobs ignition system to get a more complete burn. Could the choke plate be getting stuck partially closed? Can't think of much else. Please help. Thanks
Rob
Rob
Thanks for the advice. Pastmaster, that is exactly what I was thinking, except the sensor was $24 at Napa. I will be doing it this week and hopefully it will fix it. Could this have caused any excessive carbon buildups? I am thinking about running some type of fuel injector cleaner or something. Any recommendations? Would high test gas do the same?
Rob
89 F150 4X4
300 I-6, 5 spd
For Off Road Driving
Rob
89 F150 4X4
300 I-6, 5 spd
I really don't know about the carbon buildup. I replaced my sensor last summer, when I replaced the hoses and did a complete flush...You could tell a definant difference.
Also, you might consider completely cleaning the throttle, with a brush and TB cleaner...It perks up reponce, and cures hesitation/surging. It may help you out.
