95 F-150 pinging on 87 octane with 5.0 V-8
I have a pinging problem when I run my truck on 87 octane gasoline. I have cat-back duals with no mufflers, K&N air filter, and JBA headers. The truck runs real good, but I am curious why it pings on 87 octane. I run 93 octane and it doesn't ping at all. The truck is stock otherwise, and the only thing I can think of is the thermostat that is a stock unit. The factory stat is 195 degrees I think. Would a 180 degree unit help. I am thinking of installing a chip to get more power out of my 302. Any makes that are good (Hypertech etc...)??
1995 F-150 XL 5.0 V-8 AODE or E4OD??
cat-back dual
JBA headers
K&N filter
cat-back dual
JBA headers
K&N filter
Bulk,
I have a 93 with a similar setup. You might check your timing, it should be set at factory 10 degrees BTDC, and the computer pushes it to about 17 degrees. I reset my 89's timing to 14 as well as my 93, and it pings on WOT, but not bad at normal speeds. I have the Hypertech chip, which I paid dearly for, and I feel the SuperChip is a better deal, it has more power and is a bit cheaper. The thing youll maybe regret is the chip requires at least 90 octane, which adds up after awile.
Toydestroyer1@yahoo.com
1993 F-150302/e4od/355 Limited slip. dual exhuast w/o mufflers,2 1/4" pipes with Echo Tips, headers, accel plugs/wires(8.6mm)/rotor/cap, hypertech powermodule, 4 degree advance,Blaster Coil,MSd 6A Ignition, TPS Mod,hopefully roller rockers in the future!!5% dark tint. Alpine cd player and Pioneer speakers.
1989 F-150 XLT 4x4
2000 Superduty CrewCab v-10, auto,2wd, Dad's company truck
1989 F-150 XLT 4x4
