I Hate Check Engine lights...
Old Aug 20, 2008 | 07:02 AM
92rwd's Avatar
alright, so i'm driving home from work this morning and my CEL comes on for a second, but goes off. i go get gas, heading home it does it again, so i check the codes, here's what i got...
#332 - EGR Valve Not Opening
#522 - Neutral/Drive Switch
As for the EGR, where can i get a block off?
What is the Neutral/Drive Switch and what does it do?
Thanks.
Old Aug 20, 2008 | 09:34 AM
subford's Avatar
A Code 522, 525, or 528 resulted from the voltage being high at either:
-- Pin 10 = A/C input
-- Pin 30 = Neutral drive
while cranking the engine or during KOEO test.
Possible causes:
-- A/C circuit shorted to power
-- Clutch engage/interlock circuits open
-- Neutral drive/gear switch open
-- Damaged processor
-- Starter relay disconnected during Self-Test.
Old Aug 20, 2008 | 09:37 AM
subford's Avatar
You can get one at:
http://rjminjectiontech.com/?p=9
Old Aug 20, 2008 | 08:07 PM
92rwd's Avatar
could it have been that the truck was in reverse? it's a stick and i park it in gear.
Old Aug 21, 2008 | 06:49 AM
subford's Avatar
No, that would not do it.
It would have to be something like a bad starter relay or the start wire off of the relay when you did the test. Could also be bad wiring in circuit from the computer to the start wiring or a bad pin in the computer plug.
Does it start (crank) OK?
Old Aug 21, 2008 | 03:10 PM
coloredred's Avatar
The EGR valve could be due to loss of vacuum. My check engine light is always on, I've changed EGR valve, Solonoid, rusted connector and all vacuum lines and my codes still say I have something wrong with EGR. I have an 89 with 4.9, my next piece to replace is something with the initials ACV.
Old Aug 21, 2008 | 03:26 PM
subford's Avatar
I think you mean the EVP sensor.
Old Aug 21, 2008 | 08:57 PM
92rwd's Avatar
starts and runs, i drive it every day.
Old Aug 21, 2008 | 09:38 PM
subford's Avatar
Did you turn the key to the start position during the test?
Old Aug 29, 2008 | 07:32 PM
Vellicate1995's Avatar
For the EGR code, inspect the vacuum canister. Mine was throwing the same code intermittently and the canister ended up having a hole in it or restricted. I just bypassed it with a short piece of vacuum hose and problem solved.
