How to verify a bad PCM
Old Feb 19, 2008 | 06:43 AM
T30's Avatar
T30
My CEL came on recently and it had 18 codes stored basically a bunch of sensors didn't report, and one code 513 is replace PCM. I would like to do what I can to verify it's bad before replacing it, as I cannot afford to throw parts at it.
My truck is a '94 F350 5.8L E4OD 4X4.
Anyone got a spare PCM I could borrow?
Old Feb 20, 2008 | 12:15 PM
subford's Avatar
Does the truck run OK?
When you turn on the key does the fuel pumps run all the time without the engine running?
Old Feb 26, 2008 | 06:37 PM
T30's Avatar
T30
it runs rough. The fuel pumps run for a secone then shut off
Old Feb 26, 2008 | 07:33 PM
subford's Avatar
Check the 5 VDC Ref. Voltage and if is 5.0 +- 0.05 V then it is more than likely OK.
Run a self-test and see if it checks out OK with the codes.
If it passes the codes and the 5V I would say it is a good one.
Make sure you run all of the code tests and the timing test.
You do not need anything special to do these tests, just a paper clip and a meter.
If you do not know how to do the tests go to one of these sites links.
This is good for the KOEO test:
http://fordfuelinjection.com/?p=13
This one is good for the KOER test:
http://www.broncodata.com/tech/codes.htm
Old Feb 26, 2008 | 08:58 PM
adrianspeeder's Avatar
Unbolt the connector off the computer and make sure there ain't bad corrosion.
Adrianspeeder
