front end "clunking" noise.
Old Sep 21, 2007 | 07:02 PM
lifeson's Avatar
on my '93 f-150. 4.9l 59,000 miles...i have a clucnking noise once in a while when i brake and when i turn the wheel sitting still and making turns.. it is not all the time.... i have greased the fittings...
thanks for any help!
also i am having a slight miss when i am at idle...i change the plugs and wires .and roter and cap. is that normal for this motor?
thanks!!
dan
Old Sep 21, 2007 | 07:24 PM
F151's Avatar
An ocasional "hard hit" at idle is not uncommon for the 4.9L. All the ones (3) I've had did it. And look at you ball joints.....
Old Sep 21, 2007 | 07:45 PM
Steve83's Avatar
Click my black Bronco below & look in the Frame Noise album (near the bottom of the list). Read all the captions.
Old Oct 3, 2007 | 12:35 AM
lifeson's Avatar
thank you ...been busy.. very helpful info..
Old Oct 3, 2007 | 08:20 PM
ratio411's Avatar
I have 3 trucks that have been making front end noise lately.
2 had bushings missing from the front shocks, causing metal to metal where there is supposed to be rubber cushion.
The other had the stud broken off the top of the shock and it was banging against the coil spring at times.
I fixed 2 of the 3.
I suppose I'll install another set of shocks next week.
It's getting old about now.
Old Oct 7, 2007 | 11:31 PM
crashogden's Avatar
its the radius arm bushings my truck was doing the same thing but then i replaced them and the noise quit
Old Oct 11, 2007 | 10:06 AM
flex2slick's Avatar
Minbe too
I have a 92 F 150 and i have been getting that same clunking noise in the front end for the past 75000 miles, basicaly since i got the truck. I was told its something to do with the front end, dried out hard rubber somethings. The only way to fix it is to drill out spotwelds and replace the rubber then put bolts where the spotwelds used to be, if you get your fixed lemme know how it went casuse i gotta do mine, i also got a busted leaf spring but thats another stroy.
Old Oct 11, 2007 | 04:36 PM
Steve83's Avatar
Click my black Bronco {in my signature} & look in the Frame Noise album (near the bottom of the list). Read all the captions.
