Need advice on fluid changes.. Trans, transfer case and front and rear diff
Old Jun 3, 2007 | 05:25 PM
Dan71's Avatar
I have a 96 F-150. Im going to get the trans filter kit and diff gasket from Ford.
Trans is an AOD,
Need recommendations for the Front and rear diff fluid... rear diff is a limited slip.
Transfer case.
Old Jun 3, 2007 | 07:15 PM
StrangeRanger's Avatar
Transmission: Mercon
Transfer Case: Mercon
Front Diff: 80W90 w/ 3 oz. of friction modifier if it has a limited slip
Rear Diff: 80W90 w/ 4 oz. of friction modifier if it has a limited slip
Old Jun 3, 2007 | 10:16 PM
Dan71's Avatar
Thank you sir...
Any brand gear oil? Like the purple stuff or something or is standard gear oil and Mercon the best?
Old Jun 3, 2007 | 10:31 PM
Synthetics everywhere.
Redline, Royal Purple, Mobil1 whatever you prefer.
Old Jun 3, 2007 | 10:45 PM
BTW your trans is not an AOD, look at the trans code on the vehicle ID sticker.
It could be a 4R70E (trans code = U)
Or it could be an E4OD (trans code = E)
Old Jun 4, 2007 | 08:22 AM
Bruce R Leech's Avatar
Hyploied gear oil in both differentials
Brucew
