oil question
Old May 12, 2007 | 10:06 PM
tstjohn's Avatar
oil question
I have an '88 f150 4x4. It is a 351W and C6 automatic. I don't know exactly how many miles the truck has because I had a period of no speedometer working, then changed instrument panel. It is approximately 150,000 miles.
Rear main leaks about 1 qt of oil every 2 weeks. It doesn't seem to burn oil at all.
I have been running 10W40 conventional Motorcraft oil and a Motorcraft filter. Been using this combo since buying the truck about 3 1/2 years ago. Change the oil every 3000 miles or so.
I have been discussing synthetic oils with my brother-in-law who runs a quick lube place. He said he would switch.
Opinions? Recomendations? Change oil change intervals?
Any opinions welcome.
Old May 12, 2007 | 10:34 PM
cavinandpavin's Avatar
if you leak that much oil, i wouldnt worry about goin to a more expensive oil, those 351s must be hard on the rear mains, the wife had an 87 years ago and it did the same thing
Old May 13, 2007 | 12:26 AM
earnedit3's Avatar
Bars Leaks
Unless you want to throw money at repairing the rear main, which means dropping the transmission and all that good stuff, try going to a heavier oil, say 20w50 and throwing in a quart of Bar's Leaks Rear Main Seal Repair. Worth a try. The Bar's Leaks Radiator repair totally stopped the leak I had in my radiator, and has slowed the oil leak in my rear main--'95 F150 302 V8 with 96k. Good Luck.
Old May 13, 2007 | 08:19 PM
tstjohn's Avatar
Yeah, there's no way I'm going to pay what it would take to fix the rear main. $4 a month in oil will last until the motor needs to be rebuilt.
I will try the bars leak.
Old May 13, 2007 | 10:56 PM
lmd91343's Avatar
tstjohn,
I used Lucas Power steering stop leak in my Volvo. The P/S used about a pint of fluid a week. About 2 quarts of the Lucas product dropped the usage to less than a pint a year! I wish I tried it eight years earlier.
I've never used their Oil Stabilizers. They are supposed to stop or slow leaks. But I am very happy with their P/S product.
http://www.lucasoil.com/products/dis...tid=2&loc=show
I was following a truck loaded to the gunwales on the 57 freeway in rush hour in 1996. A 4x8 slide out off the back of the bed and boom! As I hit it, it ripped the body piece off from below the bumper and hit the steering rack. I only had the car a week! My brand new Volvo 850!
-Lance
