351 oil pan gasket.
Old May 1, 2007 | 09:14 PM
ksubigbuck's Avatar
351 oil pan gasket.
OK guys, I'm going nuts here. I'm trying to figure out how to change my oil pan gasket (f250 4X4 351 auto). According to the book I have to jack up the front of the motor to slide a 2X4 under the motor mounts...One little problem here: there is absolutely no way to get a jack on the front of the engine because there is a huge crossmember in the way. I don't think it would be a good idea to jack it up from the rear of the engine.
Can I just drop the pan a couple of inches and slide the new gasket underneath the oil pickup tube. That way I don't have to jack up the motor at all.
I can take pictures if needed.
Thanks for the insight,
Hunter
Old May 2, 2007 | 10:59 AM
Steve83's Avatar
Remove the 2 nuts from the 2 engine mounts & jack it up by the harmonic balancer (the big pulley). Then drop the pan onto the x-mbr. At this point you have 2 options, and neither is much fun: 1) try to remove ALL of the old gasket & sealer from the block & pan before wrestling the new gasket under the pickup tube & into place, or 2) reach over the lip of the pan (broken wrists help), unbolt the pickup tube (2 small bolts & 1 large nut) to completely remove the pan & change the gasket; then put it back the same way.
I've tried both, and from now on, I'll pull the whole engine to do a pan gasket on a V8.
