'96 4.9 oil pump
Old Apr 30, 2007 | 09:24 AM
weez's Avatar
'96 4.9 oil pump
I'm getting things lined up to do the oil pan gasket and have read those who say to put a new pump in while there. RockAuto lists 2 pumps for this engine:
SEALED POWER Part # 22441124 $24.89
SEALED POWER Part # 22441124V High Volume, check pan for clearance $65.79
Should I splurge on the High Volume one and does anyone know if it will fit?
Old Apr 30, 2007 | 12:05 PM
StrangeRanger's Avatar
Don't bother.
The stock pump is more than adequate on a 300.
The high volume pump substantially increases the load on the distributor drive gear.
Old Apr 30, 2007 | 12:33 PM
weez's Avatar
Will do, appreciate the advice!
Old May 1, 2007 | 03:27 PM
Steve83's Avatar
If you were willing to spend $66, check the price on a stock MotorCraft oil pump.
Old May 2, 2007 | 09:21 AM
weez's Avatar
Actually, since I'm going to all the trouble, I'm 'willing' to do the job right. The truck is in excellent condition and I hope to keep it a long time.
Old May 3, 2007 | 04:57 AM
weez's Avatar
I just need the pump only, right? ie NOT the pick-up and push rod also?
Old May 3, 2007 | 01:58 PM
Steve83's Avatar
Probably not, but only you can inspect them.
