300 Engine / part Question
Old Apr 5, 2007 | 02:49 PM
Dan71's Avatar
Thanks Steve83 for the use of the pic.
Can you tell me what #12 & #13 are? I'm guessing that #12 is a gasket and if so are they known for leaking?
Old Apr 5, 2007 | 03:02 PM
beckerjs's Avatar
tappet/pushrod cover, yes they can leak, also the oil pressure sesor is there and they can leak
Old Apr 5, 2007 | 03:04 PM
Bruce R Leech's Avatar
13 is the tappet cover and 12 is the tappet cover gasket. these are famous for leaking. mostly because of improper installation.
Bruce
Old Apr 5, 2007 | 03:37 PM
Dan71's Avatar
Is there anything that might require attention with the cover off or just change the gasket?
Old Apr 5, 2007 | 07:35 PM
the only thing you would do in there is changing the tappets or lifters and if you are not hearing any bad ones then just change the gasket.
Bruce
Old Apr 6, 2007 | 02:32 AM
Steve83's Avatar
The part names are in the caption, so if you'll post the linked thumbnail instead of the fullsize image, you'll be able to read them. It's also easier on those with dialup.
