OD and Cruise Control Issues
Old Mar 11, 2007 | 08:16 PM
Gebo's Avatar
My overdrive switch has quit working and so has my Cruise control. Since both were working and now both aren't working, are they related in some mysterious way? When I push either button, nothing lights up.
Old Mar 11, 2007 | 09:19 PM
Steve83's Avatar
Fill in your profile & add some specifics to your signature so we have SOME idea of what you're working on.
Old Mar 11, 2007 | 09:46 PM
Gebo's Avatar
'92 302. I'm the same guy with the fast idle thread. Maybe when I pressure washed my engine...???
Old Mar 12, 2007 | 02:14 PM
Steve83's Avatar
Nothing is supposed to light up for the cruise, and it's not related to the TCS (OD switch) in any way, other than they share the battery/alternator & maybe a ground wire under the dash.
For the cruise, print out these & follow the caption of the first one step-by-step.
The TCIL (OD light) is probably just burned out, so pull the codes to see if that's it. I think the cap twists or pops off (I've never done it).
Old Mar 12, 2007 | 06:05 PM
Gebo's Avatar
The overdrive button does not have any effect. It not only doesn't come on, it doesn't work. Also, the cruise does not work.
Old Mar 12, 2007 | 10:57 PM
Steve83's Avatar
What happened? Did someone do something to the wiring under the column?
Old Mar 13, 2007 | 07:00 AM
Gebo's Avatar
The plastic cover "faceplate" that covers the instrument panel was loose where the screw on the right side under that shiny silver strip had pulled through the plastic. I messed with this to get it back on. That's all I know. Could I have pulled something loose as I was lifting this up and fiddling with it?
Old Mar 13, 2007 | 05:24 PM
csonka
Guest
Posts: n/a
is your truck under the cruise control recall?
Old Mar 13, 2007 | 06:07 PM
Steve83's Avatar
Not likely, but the wiring for the cruise buttons & the TCS/TCIL run down the R side of the column, so you MIGHT have damaged them. Your column doesn't have a clock spring, but look thru these photos. Note veiw B in the first diagram.
Old Mar 16, 2007 | 06:25 AM
Gebo's Avatar
Cruise control is fixed! It was an outside issue. Now if I can get the O/D button to work...
