5.0 engine woes
Old Jan 23, 2007 | 08:02 PM
foreman400x's Avatar
5.0 engine woes
My 1992 5.0 has been spitting ,sputtering,and stalling,
I have replaced,fuel pressure regulator,cleaned throttle body twice, it seems like its running extremely rich,
Scinerio, Get it start it up, put it in reverse start to give it gas and it stalls..i dont know whats going on...ALL HELP is needed..im changin plugs right now but i got started later and didnt finish it
Please and Thank you
Old Jan 23, 2007 | 08:08 PM
signmaster's Avatar
Lots of possibilities here.
Has this been a problem that slowly happened or was sudden?
I'd start with the quick checks and go from there. Pull a plug and make sure you have a good solid fat spark. If it seems to be rich then it's more probable the spark is weak than a sudden fuel system change.
Was your old fuel pressure regulator bad or did you simply change it to eliminate it as a cause?
Old Jan 23, 2007 | 08:11 PM
it was just to eliminate it.. it came on all of a sudden
Old Jan 23, 2007 | 08:30 PM
F151's Avatar
Does it idle fine and rev up smooth in nuetral/park? I'd look into cleaning the MAF sensor.
Old Jan 23, 2007 | 08:32 PM
its speed density..has a new iac all thats to change on throttle body would be tps
Old Jan 23, 2007 | 08:34 PM
signmaster's Avatar
There are a number of things that could cause it, but I'd check for spark before anything else.
It's rare that the entire fuel system have major problems with little warning. Usually it's a gradual thing, or something that affects only specific driving conditions.
Check plugs and ignition stuff first, then go from there.
If you have something to check them with, check the wires for resistance also. If everything else is in good tune a bad primary or a few bad wires can cause similar symptoms. I had an ignition box fail and disconnected it. I had a slight sputter a couple of times after that, but only when the truck was cold and the weather very humid.
The primary wire had huge resistance from when the box fried. It even gave some spark at the plug, but after seeing the resistance it's hard to believe the truck even ever started, much less ran ok.
Old Jan 23, 2007 | 08:42 PM
my dads goin to get me wires,and rotor tomorrow and a cap
Old Jan 23, 2007 | 10:23 PM
Steve83's Avatar
Changing parts is the least effective & most expensive way to fix anything. Get a Haynes manual & a cheap digital multimeter, and TEST things instead of replacing them. I'd test the TPS, the MAP, the ACT, & the ECT.
Also, check this:
This is very important, since you've been messing with them.
