new crate motor, old ignition won't start
I have a 1991 f150 that I replaced the original engine at 220k with a Jasper crate motor. The old engine was starting to show alot of signs of wear and after window shopping for a new truck I decided to go the cheaper route. The problem I'm having is the truck will run fine and then just quit. After it sits for awhile it will start and run fine. I have replaced the alternater,battery, icm, distributor, coil, ignition harness, the pcm, both fuel pumps and fuel tanks. After doing all this I surrendered and took it to a local shop with a good rep. and after three times back to the shop they are just as perplexed. Any thoughts would be greatly appreciated.
Does your year truck still have the TFI module on the distributor?
If so, it sounds like the TFI module is having heat issues. This is a known problem and why Ford moved it to a heat sink on the firewall in later years. Replace the module.
Originally Posted by Cole1960
That was my thinking. I am just tired of the parts swap. And no I'm not getting any codes.
Good luck!
Mike
FYI...try to find a place that has a real-time ecu monitor. In other words, a computer that can be hooked to your vehicle that displays the actual sensor readings while the engine is running. If you can duplicate the problem while watching the sensors, you should be able to pin-point the issue.
