351W redline
Run out of breath. The stock heads aren't known for their RPM potential.
By "redline" do you mean the RPM which you want to shift at when you're flogging it, the RPM which you never want to exceed or the RPM above which things begin to spontaneously self-destruct?
The answer to the first is about 200 RPM above your HP peak, look it up
The second is probably somewhere around 5000-5200 RPM.
The built in rev linmiter should handle the third one.
