ignition switch problem??
have a 95 f-150XL v6 it starts fine but when you turn the back to shut if off nothing happens. So i changed the ignition switch but, its not the switch. Now i see when i turn the key there is a white PLASTIC square rod that moves along the steering column. So in order to shut it off I have to jam a screwdriver in to push this rod up and it shuts off. O.K. now is this rod one full piece that is now broken? or is it just disconnected somewhere? And what is it called so i don't look stupid at the parts store.
Please Help!!!
Please Help!!!
on
You won't find it at a parts store, and Ford probably won't sell it, either. It's an internal part of the steering column, requiring extensive disassembly to replace, and they'd be partially liable if you put it back together wrong & got killed, or killed someone.
Just snag a whole column from a JY - there are MANY vehicles that use the same one, even though they may look VERY different. Look thru these pics & diagrams.
on
A) You don't have to "deal with" the airbag. It's totally safe. Pull the 4 nuts, pull it off the wheel, & disconnect it - NOTHING to it. Just store it UNDER the truck, face UP for safety.
B) You'd have to go VERY deep. Just swap the whole column. It's very rare for that part to break, so you won't have to worry about it again.
