Battery Light
Old Dec 6, 2006 | 10:30 AM
rmwright's Avatar
Battery Light
Howdy, ...read the previous thread about the battery light...I had the same scenario, battery light came on, truck ('94 F-150) died. I swapped out the battery (it was old), and had a shop change the alternator (it was dying). But I still have the battery light on the dash lit. The new alternator is working correctly.
Any other ideas as to what the problem could be? I would appreciate any suggestions.
Thanks!
Richard
Old Dec 6, 2006 | 11:45 AM
adrianspeeder's Avatar
Howdy and welcome Rich!
Have you verified the voltage at the battery with a meter while the engine is running? Also take a looky at all four ground wire connections on the main ground cable. Common to have that corrode.
Adrianspeeder
Old Dec 11, 2006 | 11:16 PM
Hamish's Avatar
What spots other that the battery and starter should I look for my battery light has been on for a year or more I have had the truck looked at twice. The only way I can get the light off is to pull the black plug on the alltornator and it goes out, I thought that when you pull the plug the battery light should be on and it goes out?
Old Dec 12, 2006 | 10:07 AM
Steve83's Avatar
Virtually all Fords use this circuit for the alternator...
...but some have the W/Bk circuit internal.
So if you unplug the large connector, the light will go out because it's then on an open circuit.
Old Dec 12, 2006 | 11:04 PM
Hamish's Avatar
What should I do if my battery and starter connects are clean to try and get the battery light off, I have had it tested twice in a year and the garage says its fine. The light came on when I was driving down a back road to fast and came over a hill and hit a washout the light flashed on and off and back on permantly for over a year?
Old Dec 13, 2006 | 01:11 AM
Steve83's Avatar
Originally Posted by Hamish
...battery and starter...
I have had it tested...
Had WHAT tested? The alternator (voltage regulator) controls the dash light, so THAT's what needs testing.
Old Dec 13, 2006 | 08:34 AM
Hamish's Avatar
when the truck is running the altanator is charging but the battery light in the dash is on.
Old Dec 13, 2006 | 10:23 AM
Steve83's Avatar
Then don't worry about the light.
