Engine swap
Old Nov 15, 2006 | 09:26 AM
esm's Avatar
esm
Engine swap
Hi there hope someone will be able to help a proud f150 owner out.i am taking a 302 out of a 90 f150 and putting it into a 1994 f150 my question is the main harnesss is not the same what should i do
thanks
Old Nov 16, 2006 | 03:51 PM
adrianspeeder's Avatar
Yeah, the 94 is gonna have some differences. Such as...
a possible non electronic tranny in the '90 (C6, AOD) vs. an electronic one for sure (E4OD or 4r70w) in the '94. But the '90 could also have the E4OD. Does it?
The '90 is a speed density setup, while the '94 could be mass air flow.
Belt routing is different, and if I'm not mistaken the firing order is too.
Adrianspeeder
Old Nov 16, 2006 | 04:47 PM
89Lariat's Avatar
Just swap the electronics from the 94 to the 90 engine. The engine itself is the same
Old Nov 16, 2006 | 06:11 PM
ratio411's Avatar
I would just use your existing wiring harness.
Unless you originally had a 6 cylinder???
One problem you might find, the 90 block will probably not have a boss to mount a knock sensor.
I have that issue on my truck from swapping in an earlier block.
It has yet to run decent on a consistent basis, and won't run on any fuel other than 93 octane.
Dave
Edit: Sorry, 90 models did have the knock sensor...
You should be okay. I was thinking wrong year.
