Help reading codes please
Old Nov 5, 2006 | 05:51 PM
MrKooL's Avatar
I took advice from the guy at pepboys and bought a decoder and a haynes service manual for a 95 f150 4x4 5.0. The great thing is that the decoder actually tells you codes of whats wrong. Unfortunately i had to settle for the base model (the one with the flashing red light) instead of a digital screen. I tried getting a digital one but my truck just misses it by 1 year . It does up to 96 well i have a 95 so either spend 300 bux on a digital one or spend thirty and count beeps. So i counted the beeps and it looks like i have a code #12 . when i look up 12 in my code book, it says "system cannot raise engine speed above normal idle". What the heck does that mean? I spent a few hours lookin thru my hayes manual but that thing is almost as good as a childrens book, hardly has anything i could use in it the index is terriable. Will someone please help me get the answers to my problem, your knowledge will be greatly appreciated.
Old Nov 9, 2006 | 11:53 AM
bigbronc's Avatar
Try cleaning the iac. The computer uses this to raise engine idle speed. It may be stuck, or malfunctioning. The computer only sends a signal out, but doesn't know if it is working or not unless the rpms raise.
Old Nov 9, 2006 | 11:23 PM
MrKooL's Avatar
How should i check it? Do you think you could give me an idea where i can find info on how to. My manual isnt specific enough. I really appreciate your help
