78 4x4 parts fit a 73 2wd?
Old Aug 31, 2006 | 07:54 PM
Randysford's Avatar
I have a 73 f100 2wd with a 302, C6. The motor is bad and rear end is bad. A friend of mine has a 78 Bronco 4wd, 400M, C6, NP 205. It also has a 6 inch lift on it. He wants just $200 for it. The motor runs great. My question is will everything be a direct fit into the 73? I know i'll have to cut a hole in the floor for the T-case. But will motor mounts work? Will the front axle bolt right in? Any help appriciated. Thanks
Old Sep 1, 2006 | 10:13 PM
adrianspeeder's Avatar
I believe the Windsors have different mounts than the 400. But for sure everything will "bolt on" to the 73 that you need to take off the 78. These older trucks are very forgiving on doing swaps like this.
Adrianspeeder
