1992 F-150
Old Aug 17, 2006 | 10:49 PM
Remington22's Avatar
1992 F-150
Hey guys i just recently got my first vehicle....Its a 1992 F-150 XLT. Its sporting a 4.9L Inline 6...Only got 50k on her and only one rust spot on the fender. I was wonderin if i should worry about teh dual tanks over flowing. I read on here it was a problem for this year...Was there certain model numbers or was it for all 92s. thanks
Old Aug 20, 2006 | 10:31 PM
richhamn's Avatar
I wouldn't worry.
I have a 92 F150 Flareside with dual tanks that have never been a problem. I did receive a recall a few years ago but didn't do anything about it. Mine have been doing fine now for about 190,000 miles (hopefully a few more!)
Old Aug 20, 2006 | 10:40 PM
92f150302's Avatar
ive got a 92 and ive never had a single problem with the dual tanks, but you should worry about the rust on the fender, itll only get worse and a reputable body shop near me wants 2k for bedsides start to finish
Old Aug 21, 2006 | 03:29 AM
slow150's Avatar
mine has the overflow problem...i just run the front dry and fill the rear up...when i'm at the gas station i check the front when it say's full i run it out...
Old Aug 21, 2006 | 09:39 AM
adrianspeeder's Avatar
Howdy and welcome!
Get that rust fixed now before the cancer spreads. I always did think that was a sharp paint scheme!
Looks like a five speed? Take the 20 minutes and get four quarts of fresh Mercon ATF in the tranny to keep it happy.
Oh, and more pics are required for you to stay here on the site.
Adrianspeeder
Old Aug 24, 2006 | 10:33 PM
Well ill keep in eye on it..otherwise a guy said he just puts half in back and the other half in front...The rust spot is on the driver side fender....Its hollow....Ill take some pics....Should i just scrap out all the loose stuff and fill it with bondo or what? THanks
Old Aug 25, 2006 | 09:02 AM
subford's Avatar
The problem was for the 1993 year as they had bad check valves in FDM that year. Ford recalled them and put a check valve in the pressure lines coming out of the tanks.
The tank that is overflowing is the one with the bad valve(s), either the check valve or the shuttle valve in the FDM.
Of course these valves can go bad in other years from 1990 on, the 1989 and older could have an overflow problem but it is not the valves in the tanks defect.
