Electrical Woes.. Air Bag Code 52
Old Apr 17, 2006 | 08:06 PM
msd1000's Avatar
I recently had left the windows open on my truck the other day and it rained like you wouldnt belive it.
I ran into three problems the next day the blower motor on the climate control wouldn;t shut off with the ignition off and the pass side airbag light would remain lit if it was in the off postiion and the ignition off.
I grabbed my wet dry vac and vaccum all the water out and took all the panels apart,checked relays, etc and also disconnected the battery. The problem with the blower and pass air bag light is fixed, but now the main air bag light is on flashes 5 -2 I have done a search on this but there is little or no information. Can someone please help
Old Apr 21, 2006 | 01:11 AM
msd1000's Avatar
Bump
Old Apr 21, 2006 | 10:17 PM
projectSHO89's Avatar
Originally Posted by msd1000
Bump
Since you didn't give any identifying info on your truck...what manual to use?
Year, engine, transmission at a minimum. We don't care what color it is.
Old Apr 22, 2006 | 10:17 AM
msd1000's Avatar
My bad
1997 Ford F150 4.6 2wd 5 speed, Flare Side Body
Old Apr 22, 2006 | 07:46 PM
usedtodrivechev's Avatar
My 94 f150 had the air bag light flashing out of no where. It wasnt consistant either. it would flash 3 to 5 times the stop for a few seconds and continue. The cruise and horn stopped working as well. Both on the steering wheel. Took it to the dealer and it was something called a clock ring i believe. Cost about 200 for parts and labor.
Old Apr 23, 2006 | 09:49 AM
msd1000's Avatar
I ended up bringing to a local dealer, I just tripped the battery and 52 is a loss of power. All that had to be done was to be cleared. Now my dashboard looks nice without any flashing lights
